xref pdf error
xref pdf error
xref pdf error
Hey All,
I'm using Architecture 2014 and am trying to xref in pdf. When I try I get this error, what might be causing this?
imadHabash
the dialog image that appeared for you is telling you about the reasons why Architecture 2014 couldn't deal with the pdf file . so you have to find the proper reason that cause your problem and start to fix it.
Good Luck..
Imad Habash
Victoria.Studley
Hi @Anonymous,
As @imadHabash mentioned, typically this error indicates that the PDF file itself is corrupt. There are a couple of options here:
  • Can you attach the PDF file via another computer? (If so, the issue may be machine-specific, as noted in this thread.)
  • Can you attach the PDF via another version of AutoCAD?
  • How was the PDF originally created? And can you recreate it to see if a new version will attach successfully?
If you post a copy of the problematic PDF here, we can test it here to see if there's anything else we can do to help.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help here. Were you able to resolve the error with your PDF using the recommendations that @imadHabash or I made?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
