xref cancel
xref cancel
xref cancel
PLEASE HELP!!! when I type XREF, CAD says *cancel and the xref window doesn't show up, therefore I can't update my drawings unless I close and reopen.I know that without CAD life would suck but using Autocad has to be the most frustrating thing about my career, there is always a software issue with you guys :C
I've reset the profile on the options menu but it didn't work.
I also tried different files and the same happens.
leothebuilder
Do all the other commands still work?
Have you checked other commands that use dialog boxes?
Do you have single or dual monitors?
Is the xref dialog box off screen somewhere?
pendean
Community Legend
Community Legend
Try CLASSICXREF command and -XREF command (there is a dash in the name): do these cancel too?
