Write multiple blocks as individual .dwg files simultaneously?
I found the instructions for how to export a single block here:
To Save a Block as a Drawing File
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
I need to know if I can export multiple blocks to individual .dwg's simultaneously.
pendean
Community Legend
Community Legend
What are you trying to do with those after they are out of the min file exactly? Explain, there are probably better options to consider.
Otherwise in this the year 2020 Google Search answers your question https://www.google.com/search?q=autocad+tip%3A+wblock+all+blocks+at+once
I have one file that contains multiple detail blocks. I want to turn all of those blocks into individual .dwg files, which I can then insert as x-ref's into other drawings as needed. I don't fully understand the link you posted, but I'm on 2019.
pendean
Community Legend
Community Legend
I'm going to check it out. IT needs to review first...
David_W_Koch
Duplicate suggestion - failed to refresh page before answering.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
