Where ate the Plot Styles kept ?
cliffordjohnturner
cliffordjohnturner
When I attempt to plot, in the Plot Style Table, our Pen Assignments are not listed.
I did a search and found 3 of them in 3 different folders, none of them found by AutoCAD.
Which folder should I place our Pen Assignments so that AutoCAD will find them?
pendean
Community Legend
Community Legend
Start STYLESMANAGER command (type it at the commandline) and your session of AutoCAD will open that folder it uses for you.
BUT... if your DWG file is set to use CTB it will not show you STB plot style tables.
And if it is set to use STB it will not show you CTB plot style tables.
Make sure that's also not what might be going on.
HTH
rwrightWMDSY
With a drawing open, on the command line type OPTIONS.
Click the Files Tab and scroll down to "Printer Support File Path". Open that and look for "Plot Style Table Search Path".  Click on that and it will tell you where your plot styles are located.
