I have a hidden line type for walls, but when I xref it in my sheet it shows it as continuous. These are demo'd walls, so they need to be dashed.
Solved by leothebuilder. Go to Solution.
Are you using ACA objects for walls?
If so, your display configuration may be different for the host and xref file.
If they are just linework, you can change the xref linetype in the hots drawing.
Or set Visretain to 0 (zero) in the host drawing, reload the xref, and change Visretain back to 1
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum! I'm just checking in to see if you need more help with this. Did the suggestion that @leothebuilder provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
