WALLGRAPHDISPLAYTOGGLE
In ACA 20008 we found the WallGraphDisplayToggle command very usefull in troubleshooting wall cleanups. In R2010 this command seems to be gone! Where did it go? Is there some other way to get this display now?
aghis_no
1. Select a wall
2. Right click to get the menu
3. Go down to the middle of the menu to find "cleanups"
4. And from the sub-menu choose "Toggle wall justification display"
5. This will display a blue line (the wall justification line) and at each end of this line you will find two inclined arrow-grips that will allow you to interactively modify the cleanup radius to troubleshoot your walls.
(Very easy to use, very interactive)
hope this helps
regards
aghis
Yep, that does the WallJustificationDisplayToggle command, which seems to do the same thing. Thanks.
