Wall opening issue
Wall opening issue
Tallans422
Message 1 of 11
Wall opening issue
Tallans422
I'm working in ACA 2016 and I get this issue when I have openings on both sides of a wall.  Adding a wall merge condition fixes it but I don't want to have to do that every time.  This happens with both default and custom wall styles that I use.
Any help is appreciated!
Todd
Replies (10)
Message 2 of 11
David_W_Koch
I am not seeing that here (ACA 2014, US Imperial template and content).
Are you certain that your openings only abut the perpendicular Wall, and do not cut into it?  Does the Wall with the Openings have a Wall Opening Endcap Style assigned to it for Openings?  Could the Wall Endcap Style assigned to the Jamb Start and Jamb End require space to resolve itself that is not provided by the Opening when it is set flush to the perpendicular Wall?
If none of the above helps, can you attach a sample drawing that exhibits that behavior?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 11
Tallans422
I didn't have the issue in 2014 either. I tested with a default wall style so I haven't made any changes to the endcaps.  If I flip the justification line the break flips as well.  The openings have a 0" offset from the perpendicular wall.
Message 4 of 11
David_W_Koch
I have now had a chance to test this in ACA 2016, and I still cannot reproduce your results.
David Koch
Blog | LinkedIn
Message 5 of 11
pendean
Community Legend
Community Legend
Can you show us your DWG file please?
Message 6 of 11
Victoria.Studley
Hi @Tallans422,
Thank you for posting your question here in the community. Could you please provide a sample drawing where this is happening?
This will allow us to analyze your file directly, to determine what is causing the problem in your files more quickly.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 7 of 11
Tallans422
Hi Victoria, Please see attached.
Message 8 of 11
Victoria.Studley
Hi @Tallans422,
Thank you for posting the sample drawing. When I open it in ACA 2016, I can see the problem with the existing walls, and nothing I've done to refresh them seems to help.
However, when I create new walls in the same style, and add openings (before or after placing the perpedicular walls), they display correctly, even inside your same drawing. This leads me to believe there may be a problem with the program on your machine specifically.
Have you tried repairing ACA 2016? If not, I recommending doing so to try to restore the correct functionality.
Victoria Studley
Message 9 of 11
Tallans422
Hi Victoria,
I did some more digging and found that I DON'T have the issue if I use my wall styles in a template I created in ACA 2014. Only in the 2016 template. I compared properties of my interior wall style in both drawings and they are identical. One other thing I noticed is that I can pick the "end" of an opening in the 2014 template, whereas I have to pick the front or back edge of the opening to select it in the 2016 template. This is the case on all machines that I've installed 2016 on.
Very odd.
Todd Schuette | CAD Operations Supervisor | Henry Schein Dental
625 Hutton Street, Suite 102
Raleigh, NC 27606
henryscheinintegrateddesign.com
[cid:image003.png@01D16E49.65D74610]
Crazy factoid - The first two people to file patents for the golf tee were dentists!
[smallyoutubeicon]
Please consider the environment before printing this email.
E-mail messages may contain viruses, worms, or other malicious code. By reading the message and opening any attachments, the recipient accepts full responsibility for taking protective action against such code. Henry Schein is not liable for any loss or damage arising from this message.
The information in this email is confidential and may be legally privileged. It is intended solely for the addressee(s). Access to this e-mail by anyone else is unauthorized.
Message 10 of 11
David_W_Koch
@Tallans422 wrote:
Hi Victoria,
Very odd.
Raleigh, NC 27606
I am not seeing that in 2014 or 2016.  Perhaps, in your 2014 template file, you have the Width Lines component turned on for Openings in the active Display Representation in your plan view.
David Koch
Blog | LinkedIn
Message 11 of 11
Tallans422
You nailed it David.  I don't know why I didn't think of that but it was the Med. Detail display representation for openings that I forgot to change with my new template.  That took care of the issue.
Todd
