Wall Intersection Priority Settings (Existing & Proposed)
Jake_PCH
Jake_PCH
Is there a way of prioritizing existing components over proposed at intersections?
Using the below as an example; is there a method to prevent the proposed wall intersecting the existing wall other than flipping the justification of the existing wall?
R_Tweed
I'm not sure I understand the overlapping of existing with proposed.  Are you using renovation mode? Could you post your example?
If you want the wall to pass through and break, you could use the other wall as a subtractive bodymodifier.  If you ever move the wall, then the gap will move.
David_W_Koch
If the intent is to have the new, horizontal Wall stop at the right side of the existing-to-remain vertical Wall, you could just pull the grip back to the right face.  If you find that the Wall is still snapping to the justification line (which, in this case, I assume, is on the left side of the existing-to-remain Wall), check the settings on the Object Snap tab in the Drafting Settings dialog.  You likely have the Allow general object snap settings to act upon wall justification line toggle checked.  That will force snaps to act on the justification line.  Uncheck that and you will be able to snap perpendicular to the right side of the Wall.
I would also recommend setting up a separate Wall Cleanup Group for Existing-to-Remain and applying that to your existing-to-remain Walls so that they do not clean up with your proposed Walls.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Jake_PCH
@R_Tweed , Yes I am using renovation mode.
@David_W_Koch Un-checking the General Object Snap setting in drafting setting helps me achieve what I was after. However, as the 2 walls are no longer associated, they no longer work 'parametrically' together (ie. horizontal (in plan) walls extending/shortening when the perpendicular (vertical in plan) wall is moved laterally). Is there a way to retain their association while achieving the same appearance?
With regards to 'Wall Cleanup Group' - could you please elaborate on what you are referring to with this suggestion?
David_W_Koch
@Jake_PCH
One of the properties of Walls is Cleanup group definition.  There is a Standard Wall Cleanup Group by default, and that is likely what all of your Walls have assigned to them.  Wall Cleanup Groups allow you to establish two or more groups of Walls that will only cleanup with other Walls that have the same Wall Cleanup Group assigned.  This can be handy in renovation work if you put your existing-to-remain, existing-to-be-removed (demolition), and new construction Walls all in the same drawing file.  Assigning each set of Walls to its own cleanup group will allow you to freeze the existing-to-be-removed Wall layer and not have the new construction Walls show with gaps where the unseen (frozen) existing-to-be-removed Walls cross them.  Freezing a layer does not stop Wall cleanup.
As for maintaining the relationship of the end of a new construction Wall to a component face that is not the justification line of an existing-to-remain Wall, I might argue that the existing Wall should not be moving, but I suppose you could get field survey data after the drawing was set up and that existing-to-remain elements may move to coordinate with that.  If you really want it and are willing to go to the effort, you could add AutoCAD Aligned constraints from the end lines of the new construction Walls to the faces of the existing-to-remain Walls and set the distance to 0.  I will note that I have not used constraints extensively in AutoCAD with any type of objects (AutoCAD or AutoCAD Architecture), so I cannot promise that using them will not have consequences later on.
David Koch
Blog | LinkedIn
Jake_PCH
Wall Cleanup Groups sound very handy for renovation work and as for utilizing constraints, that's a great suggestion, thank you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
