AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wall hatch different when XREF'd
1 REPLY 1
335 Views, 1 Reply
My Wall hatch is appearing different when XREF'd into a separate file. We have standard wall styles setup with different hatches. Wall hatches appear the same in each file when originally created in that file, but when the same wall styles are XREF's into the file, the scale of the hatches becomes very small, making it appear solid when printed. I have attached 2 files, (Wall Test) that shows the wall styles and hatches properly, and (Wall Test XREF) that shows both the wall styles and hatches properly, these walls were created in the file, and the wall hatches that are not coming in properly, that have been XREF'd.
1 REPLY 1
David_W_Koch
See my response at your other post, here:  https://forums.autodesk.com/t5/autocad-architecture/wall-hatch-different-when-xref-d/td-p/8888536/
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
