Want to have a variable thickness wall assigned to a tool palette. Once assigned to the palette, I'd like to be able to ASSIGN a thickness to the tool. When I select properties for the particular tool it appears that I can do that. However, when I draw the wall it the thickness reverts back to the last used wall tool (or something along those lines).
What I'm trying to do is eliminate all the different wall thicknesses for basic wall types and change the thickness at the project level.... but in reality only have 1 variable wall thickness type.
When I modify the cleanup type & justification in properties the change sticks, but for whatever reason, the thickness (width) does not.
