Unable to add vertices to endcap profiles
amapostolou
amapostolou
I am trying to modify endcaps for walls but, I cannot stretch existing ones or add additional ones.
Looking for a solution.
Anthony
David_W_Koch
Are you trying to edit the endcap in place?  That is working for me, in ACA 2022.  The only way I could find that would interfere with that is if the current layer was turned off.  Then I was only able to edit one component; the other components were not selectable.  Having the current layer turned off is not a common thing (in my experience, anyway), so that may not be the issue you are experiencing.
If you can provide more details of your workflow (perhaps a Screencast?), that would help us understand what you are doing and may allow us to offer better suggestions.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David_W_Koch
@amapostolou
Here is a quick Screencast showing an example of editing a Wall Endcap in place, in AutoCAD Architecture 2022 (2022.0.1, on AutoCAD 2022.1.2; but this also worked in 2022 without the updates installed).
David Koch
Blog | LinkedIn
amapostolou
I installed the Screencast and my computer doesn't like it.  It's a work computer and I haven't had time to ask IT to assist.  I understand the edit in place feature, and have used it.  That's where I tried to remove the vertices.  I'll muddle through it.  I do like the direction ACA is taking our drawing creation.
Thanks for the replies.
Anthony
