Tool Pallette
Tool Pallette
Message 1 of 20
Tool Pallette
Does anyone know where the AutoCAD 2016 tool palette is at and how to get it to appear and find the tab on it of architecture tab?
Replies (19)
Message 2 of 20
David_W_Koch
This blog article explains one way to do so.  (The article is on the "old" side, but the process is the same - substitute "AutoCAD Architecture" for "ADT".)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 20
I'm not finding the specific exe file in the files - AecCB47.exe - and how do I download ADT or get that on my computer and what does ADT (AutoCAD desktop - I'm guessing) stand for and what is it?
And how do I substitute AutoCAD 2016 for ADT what do you mean by that?
I have A360 Desktop and Autodesk Recap 2016 as what came with when I downloaded AutoCAD 2016? can I use that or is that the same thing?
I was able to find the Tool Palettes File Locations category in AutoCAD 2016 under files but what do I do with it. I was unable to execute steps 6 through 11 in your article?
Message 4 of 20
pendean
Community Legend
Community Legend
You don't "substitute' AutoCAD2016 for any other version of AUtoCAD2016: do you actually have AutoCAD Architecture 2016 installed on your PC?
Or are you just looking for this TP samples tab in plain AutoCAD2016
Start ABOUT command and read the line that describes your autocad version and post it here.
Message 5 of 20
I have downloaded version imperial, global and metric on my computer. I had some tech guy install it from the company so I'm not really sure what he did. I'm using imperial version of AutoCAD 2016. I have a tool pallette but it doesn't have what it seems your picture is showing it doesn't have civil, electrical, mechanical, architecture in that context menu you have. I do have a context menu of list of options but not whats in your picture. I think it is a full version but a downloaded version if that makes sense.
Message 6 of 20
I have AutoCAD architecture 2016 downloaded and on the context menu I have and at the very bottom of the list of the context menu it has - ribbon tools - architecture (US Imperial)  as an option and when I click on it pulls up blocks and tags and things of that nature to choose from thats supposed to be on the ribbon or has something to do with the ribbon - and things like that but not what I'm looking for though. or whats on your screen as an option.
Message 7 of 20
pendean
Community Legend
Community Legend
My earlier screenshot was from plain AutoCAD since i was a plain AutoCAD question that I was asking.
I no longer run an old version of ARCH2016, so I do not recall what was on the Ribbon, nor what you think should be there. Here is a screenshot from my ARCH2020 version, compare to yours and let us know if you see what is missing here vs what you have on your screen in 2016
Message 8 of 20
David_W_Koch
@Anonymous
The article was written in November of 2005, for Architectural Desktop 2006 (ADT 2006).  Architectural Desktop was the name of the program through the 2007 release.  In 2008, it was renamed AutoCAD Architecture.  You will not have an AecCB47.exe file; that was specific to the 2006 release.  You do not need it, either; that was part of an aside indicating that I did things the hard way before I figured out the easy way.
For AutoCAD Architecture 2016, if you have installed things using the out-of-the-box settings, your local Tool Palette File Location for US Imperial content will be:
C:\Users\YOURUSERNAMEHERE\AppData\Roaming\Autodesk\ACA 2016\enu\Support\WorkspaceCatalog (Imperial)
where you will substitute your Windows user name for YOURUSERNAMEHERE.
The Support folder may also have additional Tool Palette folders, depending upon what content you installed.  The "vanilla" AutoCAD tool palettes are in a folder called ToolPalette:
C:\Users\YOURUSERNAMEHERE\AppData\Roaming\Autodesk\ACA 2016\enu\Support\ToolPalette
So, with the desired AutoCAD Profile set current, if you open the Options dialog, go to the Files tab and expand the Tool Palettes File Locations node, you can select that Node, press the Add button and then either browse to the ToolPalette folder noted above or copy/paste the folder and path.  That will make the vanilla AutoCAD Tool Palettes available in your Workspace.  If you have a specific Tool Palette Group set current, they will not appear, however.  Right click on the Tool Palettes title spine, and select All Palettes to be able to see all of the palettes, including the vanilla AutoCAD palettes.
You may have more palettes that can be shown on screen at one time.  If so, right click on the "stack of tabs" at the bottom corner - below the tabs that do show - to get a context menu listing all of the palettes.  Select one of the vanilla AutoCAD palettes to make that one current.  You will probably want to create a new Tool Palette Group to hold the vanilla AutoCAD tool palettes and then set that current, if you intend to make frequent use of them.
David Koch
Blog | LinkedIn
Message 9 of 20
Mr. Koch,
I was able to execute everything you said but it did nothing but show the tool palettes manager through my dialog box once I pressed apply and ok. the last folder on tool palettes is images and I tried with tool pallette as the last folder and images as the last folder and it still did nothing. I have no new selections or options of palettes or tabs  in my tool pallette manager in the context menu. so something is off or it didn't do something or what did I do wrong?
Message 10 of 20
Pendean,
Everything is the same on the ribbon and I have a couple more panels than you - you have utilities and I have inquires which is the same panel just different design and the buttons and names.
Message 11 of 20
Pendean,
I dont have the tabs that you have over there on the left that are open or mangers or tool palettes managers you have opened on the left.
Message 12 of 20
David_W_Koch
Just to be absolutely clear, my instructions apply to Tool Palettes, not Ribbon Tabs.2019-07-11_ACA2017_RibbonVsToolPalettes.png
I do not have access to AutoCAD Architecture 2016 at home, but the interface in AutoCAD Architecture 2017 is nearly identical, and the Tool Palettes are the same.  In any folder paths you see here, you will want to change 2017 to 2016.  In the image below, you can see where I added the ToolPalette folder to my Tool Palettes File Locations search path, so that the AutoCAD Tool Palettes would be available.2019-07-11_ACA2017_Options_Files_ToolPalettesFileLocations_AddACADpalettes.png
And here is the result - with the Tool Palette Group set to All Palettes, the AutoCAD Tool Palettes show up on the context menu when you right (or left) click on the three stacked palette tabs at the bottom of the visible palette tabs.2019-07-11_ACA2017_ToolPalettes_AllPalettes_PaletteContextMenu.png
If you are asking about Ribbon tabs, not Tool Palettes, let us know; if you are looking for vanilla AutoCAD Ribbon tabs, tell us which ones and we can explain how to get those into your Workspace.
David Koch
Blog | LinkedIn
Message 13 of 20
Mr. Koch,
I executed everything correctly I think for the tool pallette file locations folders (I tried with the last folder being tool pallette in the path and then I tried with images being the last folder in the path and got nothing different on both when it came to the tool pallette context menu) and what I'm not getting is the tool pallette context menu that you have highlighted in red. I have the other options above the highlighted red box but not the options  highlighted in red.
Message 14 of 20
David_W_Koch
You want the last folder in the path in the Options dialog to be the ToolPalette folder.  That folder should have the AcTpCatalog.atc file that AutoCAD Architecture will read to see what Palettes are defined therein.  Does your C:\Users\USERNAME\AppData\Roaming\Autodesk\ACA 2016\enu\Support\ToolPalette folder have an AcTpCatalog.atc file in it?  (Again, images here from 2017, but 2016 folder structure and files should be similar.)2019-07-12_ACA2017_ACADToolPalettesFolder_ATCfile.png
The AcTpCatalog.atc file is an XML file (a structured plain text file) that, in this case, defines the out-of-the-box vanilla AutoCAD Tool Palettes.  This file identifies the name and location of the ATC files that define each Tool Palette, which, in this case, are located in a subfolder called Palettes.2019-07-12_XMLNotepad_VanillaAutoCAD_AcTpCatalog-atc.png
The Palettes subfolder contains the ATC files that define each Tool Palette, including the Tools on each palette.  Does your C:\Users\USERNAME\AppData\Roaming\Autodesk\ACA 2016\enu\Support\ToolPalette\Palettes folder have files similar to what is shown below?2019-07-12_ACA2017_ACADToolPalettes-PalettesFolder_PalettesFiles.png
David Koch
Blog | LinkedIn
Message 15 of 20
Mr. Koch,
I was using the wrong path or the catalogs in different palette folders are showing up now. I found an acTpcatalog. and a list of tool palettes options in different tool pallette folders. I think I got it now but how can all these paths in AutoCAD so thye will all show up on the tool pallette or is that possible.
C:\Users\Wood\AppData\Roaming\Autodesk\ACA 2016\enu\Support\ToolPalette\ -         atcp catalog.atc
C:\Users\Wood\AppData\Roaming\Autodesk\ACA 2016\enu\Support\ToolPalette\Palettes\ -         21 atc files
 C:\Users\Wood\AppData\Roaming\Autodesk\ACA 2016\enu\Support\WorkspaceCatalog (Imperial)\Palettes\-    26 ATC files
C:\Users\Wood\AppData\Roaming\Autodesk\ACA 2016\enu\Support\WorkspaceCatalog (Imperial)\     -
            adtsamplepallettes(Imperial).atc      &          ribbontools.atc
Message 16 of 20
David_W_Koch
You can add multiple paths under the Tool Palettes File Locations.  Of the paths you list, you will want to add
and
That will get the main catalog files in which the palette files are referenced.  If you do not have your own personal workspace catalog, I would put the Workspace Catalog (Imperial) at the top of the list.  That is where any new palettes you add in the interface will go.
David Koch
Blog | LinkedIn
Message 17 of 20
Now how do I get the tool pallette to disappear and reappear when I need it every time I open the drawing and close it and draw on the drawing.
Message 18 of 20
David_W_Koch
I am not certain what you are asking here.  Are you trying to get the entire Tool Palettes palette to open and close?  The ToolPalettes command will open the Tool Palettes palette if it is closed and the ToolPalettesClose command will close it.  Clicking on the "X" at the top of the Tool Palettes title spine will also close it.  Or, press CTRL+3 to toggle the Tool Palettes palette on or off.
If you want the Tool Palettes palette to always be available, but take up less screen real estate:
  • If you have the Tool Palettes palette floating, you can activate Auto-hide.  Just the title spine will display, until you mouse over the title spine.2019-07-26_ACA2020_ToolPalettes_Auto-hide.png
  • If you want to dock the Tool Palettes palette, you can anchor it to one side or the other, and, like Auto-hide, the palettes will be hidden until you mouse over them.  This works with most (all?) modeless palettes, so you can stack them along one or both sides, and have them easily available when needed, but tucked away otherwise.  You allow docking and specify a side for anchoring by right clicking on the title spine of a palette2019-07-26_ACA2020_ToolPalettes_DockAndAnchor.png
David Koch
Blog | LinkedIn
Message 19 of 20
When I go to open my drawing the tool pallette appears after my drawing loads. My question is and I'm sorry for the miscommunication but how do I get the tool pallette from coming up or opening when I open my drawing after I commanded the tool pallette to close once I closed and saved my drawing? Then reopen my drawing. more less when I'm finished for the day to comeback the next day. open and closing the drawing and saving the drawing.  The tool pallette doesn't close when I go to close and save my drawing once I commanded it to do so. The tool pallette doesn't want to go away; it appears to open every time I open my drawing.
Message 20 of 20
I think ctrl+3 solved my problem on the last post.
