TEXT & FILLET
TEXT & FILLET
TEXT & FILLET
Hello there,
   I've 2 questions:  -
#1    I'm using AutoCAD 2016 and there is an issue with my text.  I've brought in some motor schedules with callouts, descriptions and voltage listed.
        My question is:  I can't seem to see the thicker, Arial text that lies within in model space, yet it prints... what do you suggest to remedy this problem?
#2    I've run across this several times as well.  When creating a fillet for a curve/arc line, the two lines will not close.
        I've tried a number of things, do you have a process of elimination for that one as well....thanks
D. Harris
pendean
Community Legend
Community Legend
#1 Use QSELECT to select the text and change it's on-screen color perhaps?
#2 REGEN or REGENALL after you zoom in: do they appear closed now?
#1 May work I have to try it when the other computer is up and running.
Will let you know.
#2 May not work, I believe we tried it. Is there another solution?
David_W_Koch
Attaching a sample file that demonstrates the two issues would be helpful.  The sample file need not be an entire production file, just a small file with text and objects that do not close properly when FILLETed.
Are the objects which you are trying to FILLET co-planar?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
