System requirements for AutoCAD Architecture
iokokkal
iokokkal
Community Visitor
Community Visitor
I would like you to tell me if the following PC specifications are suitable for Autocad Architecture 2024 including Specialized Toolsets.
Windows 11 Pro
Intel® CoreTM i7-14700 ( 5.4GHz Intel® Turbo Boost Technology, 33MB L3 cache 20 cores)
Memory 16GB DDR5 4800MT/W (1x16GB)
NVDIA® Quadro T400 (4GB GDDR6)
1TB PCle® Gen4 NVMeTM TLC M. 2 SSD
pendean
Community Legend
Community Legend
You are a little short in the "recommended" specs, so only you get to decide if that's good enough for your needs (if you are a very light and casual user of ARCH for example)
yanhan.lim
Hi @iokokkal ,
Thank you for your query on the AutoCAD Architecture community forum.
Your PC specs looks good to me, and you may compare your PC specs with the system requirements as shown above (link below for your reference)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
However, if you still do have concerns, I would recommend you trying out the product for yourself with a free trial to see if it works well enough for your workflows
https://www.autodesk.com/free-trials
Best regards,
Yanhan
Yanhan Lim
QA Analyst
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Logos_Atum
this benchmark table might be right for you. Your CPU choice probably fairs a bit better than theirs. The GPU you considered (or bought- are you planning to buy?) isn´t listed, yet it gives you an idea of how they fare in general and how much more performance you can expect as they get more pricy.
Yet to actually tell I`ll need some more detail of what you plan to do. 2D or 3D makes a huge difference.
Workstation Benchmarks
Hope this helps you to define your requirements more in detail
[not advertisement :D]
EDIT:
I managed to get Igor himself to consider the VRAM to maximum GPU render size- relation as an addition to his workstation GPU benchmarks. I think this can do a lot for us and any budget.
Dogs aren´t flammable.
carlosgarciaRSCA9
Observer
Observer
those are good specs to run the program
Logos_Atum
I´d eliminate the GPU bottleneck though. There is not a lot of differences in the top 10 performance wise, but price wise that´s worlds before performance drops.
