Style Manager dialog opens collapsed in AutoCAD Architecture
TexShalter
TexShalter
Is there a way to have the style manager window open the way it last showed the tree.
It always open "collapsed"
ACA 2016 on win 7
@TexShalter for clarity VStudley edited the original subject: stylemanager dialog opening
dbroad
I doubt it but you have a couple of options to speed things along:
  • Right click on an object and edit the style for that object.
  • Right click on a tool in a tool palette and choose edit * styles where * would relate to the tool
  • Use a command that narrows it down such as wallstyle or door style
  • Use the manage->style&display flyout and pick a specific style.
  • Create styles palette by using Customize palettes.
Architect, Registered NC, VA, SC, & GA.
Victoria.Studley
Hi @TexShalter,
I'm just checking in to see if you need more help with this. Did @dbroad's post answer your question?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
