AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Stop Dimension Style Overrides
2 REPLIES 2
ted.evans
640 Views, 2 Replies
I created the script below to adjust the Dim Precision and the rounding but every time I run it, it creates a dim override and does not change my dimstyle. I have unchecked the box in the drawing setup but it still creates the override.
-dimstyle
r
hmh_96_standard
dimdec
2
dimrnd
.5
dim
update
all
exit
2 REPLIES 2
Hi @ted.evans,
Thank you for posting your question here in the community. The DIM Update function was replaced with the -DIMSTYLE > Apply command beginning with AutoCAD 2016.
Take a look at the following article for an explanation of the change, as well as a recommendation for adjusting to the new functionality:
DIM Update no longer works
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
dbroad
in reply to: ted.evans
I don't know whether this is pertinent but it looks like your script is adding overrides and then applying the overrides to your dimensions.  If you want the dimension variable changes to be saved to the dimstyle, then save the new settings first to the restored dimstyle and then apply the settings to the dims.
Architect, Registered NC, VA, SC, & GA.
”Boost
