How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I have floor-to-ceiling window. Is there a way to get the SPACE object to include floor area of the opening in the wall (door/windowsill "floor area")? SPACE, by default, ignores the floor area under the walls completely.
Blue - what I get in default
Red - what I would like to achieve with the SPACE object
Thanks, any help much appreciated.
Hi @ixikEEA68 ,
Thank you for your query on the ACA Community Forum.
There are ways to manually create a Space object to include the recessed floor area around the door/windowsill, but there is no settings/option to enable associative spaces to include the recessed area.
I will proceed to log a wish list item on the creation of associative spaces that includes recessed areas. In the meanwhile I have provided two workarounds that may help you.
How to manually create a space object including recessed area:
Option 1 - Tool palette linework option
Option 2 - Edit Vertices
Best regards,
Yanhan
I was afraid the only way was to do it manually. Thank you for your thorough explanation; it is much appreciated.
How to buy
Type a product name
