Slab Hatch Patterns: Hatch pattern unexpectedly changes for slabs with the same style (Concrete Slab on Grade).
Problem: The slab hatch pattern appears to change based on an area threshold and I don't understand how to control this display property. Sample files attached.
Background: I have been away from Autodesk products for about 13 years. I am learning Autodesk Architecture and working through a 30-day trial. Many advancements have been made and a lot of things are the same.
As I have been working with the slab tool, I have encountered a discrepancy in the way hatch patterns are being displayed in the drawing. I started a new drawing and replicated the problem. The slabs are assigned the stock Concrete Slab on Grade style from the Imperial Design Tool Catalog. The view is set to High Detail.
I don't understand what causes the hatch pattern to change, but I have found that altering the area of the slab will cause the change to occur. I have attached a drawing file, Adobe Acrobat printout, and screen capture of the style version history.
I've spent hours trying to figure this out. Any insights or explanations would be much appreciated.
