Site plan importing from Google maps , earth or council? Trace it ? how to do?
jlofatso
jlofatso
I have drawn an outline of an existing building in Autocad. I would next like insert the site boundaries from somewhere ( Google Maps/earth ?) as an overlay(?) to add to the Site Plan drawing to show the boundaries on the drawing and to orientate the building on them. I am not sure how to go about that or what it is called ( is it Geo referencing? or Xreferencing?).
Is it possible to utilise Google maps or some other type of online maps ?( the only other maps i can find online so far are Council maps  of the zone classification but they are PDF's) What are the maps typically used ?
What is the best approach to doing this ? I would like it to be reasonably accurate.
Do i need to trace the outline of the boundary over the top of the map? what's the usual way?
What are the possible ways/ workflow procedures for making this happen  ?  Is there a simple proceedure the pro's use?
Which layer does the site boundaries / map go into / model or paper space?
Is there an example  or video somewhere ?
In practice would i need a professional surveyor to locate the position of the building or can i scale and orientate the drawing over the map layout- is it OK to use Google maps  alone for presentation drawings?   Is Google maps or similar sufficiently accurate? At what point in the design process would you need the services of a land surveyor?
Can the site plan similarly be imported into REVIT?
JLO
pendean
Community Legend
Community Legend
Did you pay Google a royalty fee to use their map? You'll find they insist on it
AutoCAD has georeferencing through your Subscription and it uses Bing maps https://www.youtube.com/watch?v=FmuPxg9vBYE
jlofatso
Thanks Dean I'll check that video out.My heads spinning with all the detailed information
 **** i should have started studying  an IT course I didnt know there was a Google maps royalty  fee but that's good to know, I'll pay them when they start paying their taxes!
