Shortcut Keys Ctrl+Fx
Hey,
I've been working on the office 'shortcut keys' lately and I've run into complications. Don't kow if it's because of something I've done or if these are 'normal' problems.
I can't assign commands to these combinations:
Ctrl+F1 - Ctrl+F4 - Ctrl+F6 - Ctrl+F10
I don't think these are Windows combinations and I don't have any commands arleady assigned to these combinations.
Any thoughts would be appreciated.
Pierre P.
pendean
Community Legend
Community Legend
Those combos already "do things" in AutoCAD here, so they are probably hard coded and not available to you to edit.
Thanks for that Dean
While on the subject, is it possible to 'unprogram' the SHIFT+W so that it doesn't activate the '_NAVSWHEEL command?
Don't know how to do that. And it's not in the Shortcut keys .cuix menu either.
Pierre P.
pendean
Community Legend
Community Legend
Many of the combos you can't change are not in the CUI: unless someone knows a workaround, that is what I've been using as my rule-of-thumb when it comes to AutoCAD shortcut keys editing.
If you don't use it, simply UNDEFINE it seems to work just fine.
