Shaded (presentation) walls not plotting
davebr549
davebr549
I have a base floor plan drawn for an existing building. I have set the display configuration to presentation and modified my wall types to display a solid shade with an 80% transparency. I then xref this into various plans. One particular plan- the xref is clipped and annotations added and saved as a "view" in the project navigator. When I xref the "view" into a new "sheet", my walls show up as planned (80% transparency) and all looks good. But the wall transparency will not plot. I am using this same setup in other sheets without a problem. Any ideas on what may be the problem?
Dave
pendean
Community Legend
Community Legend
Did you try a 50% transparency just to make sure 80% may be too dark?
Plot to another or different device or PDF to confirm the problem is not one device?
Any chance you can post a screenshot of your PLOT command pop-up?
