Selection cycling not cycling visually
So I have my AutoCAD (using Architecture 2016) set up with the old-school selection cycling, where you hold CTRL and pick overlapping objects to start selection cycling. It's supposed to work by showing the selected object as dashed, and then with each left click, the next available object will appear dashed, etc.
For some reason, it only shows one object dashed, and that one stays dashed. It does not visually cycle through the objects. But it does invisibly cycle through the objects. So if I go to erase something, and hold down CTRL and pick 2 overlapping objects, one will appear dashed, then I can left click once to select the other object, and then right click to make that one erase...but that object never appears dashed. It's basically a guessing game if I have more than 2 overlapping objects.
Anyone know how to fix this? I just want it to work the way I've always known it to work. I just want each left click to highlight a different object.
