scales annotative objects
Hi, the issue is when I turn off the "ANNOAUTOSCALE" and change scales, ACA still change annotation size (Dimension and Column grid) how I can fix this? I mean how can I change plan's scale without changing dimension text and column grid?
David_W_Koch
If you want to be able to change the drawing annotation scale without having specific annotative content change size, but remain visible, then you need to:
  1. Turn off ANNOAUTOSCALE, so that the new scale will not be added to all annotative content in the drawing.
  2. Turn on ANNOALLVISIBLE, so that annotative content that does not have the current annotation scale added to it will remain visible.
  3. Determine what scale you want the specific annotative content to display, and then remove all other scales from that content.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Hi, Thanks for your response
yes i found! its work correctly at first time!!! but if turn on "ANNOAUTOSCALE" and then turn off it, its will be a bug and not working!
I mean only once we can use this option 🙂 its bug. I make a video pls see it.
David_W_Koch
Once you turn ANNOAUTOSCALE on and add a second scale to your annotative content, that scale is added; turning off ANNOAUTOSCALE at that point will not remove any scales already added to your annotative content, just prevent additional ones from being added.
Select you annotative content, right click and choose Annotative Object Scale > Add/Delete Scales from the context menu.  In the Annotation Object Scale dialog, select the scales you do not want, leaving just the one you do want unselected, and then select the Delete button.  Select the OK button to ratify the change.2018-03-12_Annotation Object Scale_Delete.png
You will have to repeat that process every time you have content with multiple scales, if you do not want the content to change sizes, so you may want to keep ANNOAUTOSCALE turned off.  If there is just specific content that you always want at just one size, you may want to consider creating non-annotative content for that.
David Koch
Blog | LinkedIn
yes its work, now i can manage annotation objects with add or delete! sry i didn't know "that scale is added; turning off ANNOAUTOSCALE at that point will not remove any scales already" i think it was a bug. but it isn't bug. Thanks for complete answer!
