hola como estan Estoy Aprendiendo a dibujar En AutoCAD Architecture y mi Preguntas ES quiero dibujar El Plano de Mi Casa Que esta en metros Y AutoCAD Dibuja en milimetros y despued de dibujar Tengo Que imprimir En Una hoja A3 y quiero utilizar la escala de 1 cm :25cm como hago para Poner Medidas en AutoCAD ayudenme porfavor
@anthonycalderoon02 for clarity VStudley edited the original subject: escala de una casa
Translation (via Google Translate): Hi, how are you? I'm learning to draw in AutoCAD Architecture and my questions. I want to draw the plane of my house that is in meters and AutoCAD. Draw in millimeters and can draw. I have to print on an A3 sheet and I want to use the 1 cm scale: 25cm as I do to Measure in AutoCAD. Help me please.
Hello @anthonycalderoon02,
I’ve translated your question per the above as this is predominantly an English forum. Welcome to the Autodesk Community!
Could you post a sample file you're working with? This will help us understand what you're trying to do, and let us offer more relevant suggestions.
Type "units" then change your units to cm. In model space draw everything full size scale 1:1. Then in paper space you can make a viewport for the drawing any size you want including 1:25.
Nick DiPietro
Cad Manager/Monkey
