I'm trying to get the Browser started up on my 2017 copy of Autodesk Architecture. The forum states that it is available by using View, User Interface, Browser to turn it back on. Unfortunately my Ribbon isn't working either. All I get is Express Tools and the Ribbon reset command is not coming up when I right click on the ribbon. Any ideas guys?
Thanks.
Thanks, that got my ribbon back to mostly normal. View doesn't seem to have a User Interface Button though. Is there another way to turn the browser on? I really need to be able to go through parts and features.
Is there some reason that you want to start a browser from within AutoCAD Architecture(ACA)? You can enter the browser command at the command line.. Perhaps you are thinking of another kind of browser, such as the Project Browser, the content browser, the materials browser, or the styles browser. You may need to be specific.
The view -> User Interface panel should look like this when popped out.
If you are after Content Browser it can be launched from the Start menu > AutoCAD Architecture > Content Browser
If the ribbon looks wrong I wonder if you have the default AutoCAD ribbon. There is a "Reset setting to Default" icon in the Start menu > AutoCAD Architecture folder to get back to factory but it will blow away any other custom settings you have
