I stand corrected. When converting from a 3D Solid to a Mass Element, the FACETDEV value is not taken into account. The number of segments does appear to vary with the radius of the curve, but it is not necessarily the same as the FACETDEV and FACETMAX variable settings would produce if drawing a Mass Element directly. Which means this Autodesk Knowledge Network article is also incorrect:
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2... EDIT: The article is correct. It is not using the right click context menu to convert a 3D Solid to a Mass Element (MassElementConvert command), but is, instead, using the ConvertMEtoFFME command. Used on its own, the ConvertMEtoFFME command has similar results to the MassElementConvert command (no relationship to FACETDEV), but when invoked by right clicking on a Mass Element tool of the same shape as the 3D Solid and choosing Apply Tool Properties to > 3D Solid, the FACETDEV setting will be respected.
I may have been using AutoCAD Architecture 2018 last night when I replied, but just checked in 2014, 2016 and 2018 now, and got similar results.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
