RENDERING
RENDERING
BrianAbbott
Message 1 of 12
RENDERING
BrianAbbott
When I render a 3D object in lunch time break quality, the image freezes after about 3 seconds.
Is this a result of the computer performance and graphics.
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
PC specs? Vided card? OS?
ACA variant?
Rendering parameters?
How long have you waited for it to unfreeze?
Message 3 of 12
BrianAbbott
Device name W180963
Full device name W180963.shetland.gov.uk
Processor Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz 3.60 GHz
Installed RAM 16.0 GB (15.7 GB usable)
Device ID E1CB26B2-7668-459D-8152-C6C2C9EF5FAB
Product ID 00331-10000-00001-AA114
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Pro
Version 20H2
Installed on ‎04/‎03/‎2021
OS build 19042.928
Experience Windows Feature Experience Pack 120.2212.551.0
Programme is AutoCAD Architecture.
Setting was for photorealistic when rendering object.
I waited half hr. and it remained at 3sec. I was unable to close it down as the computer appeared to be frozen. I restarted the computer and lost the work, recovery went back to the previous days working.
Thanks.
Message 4 of 12
pendean
Community Legend
Community Legend
Thanks for the info.
Does this happen in ALL files, or is this the first rendering you've attempted?
It could be a bad/corrupt file. Could be more: can you share your DWG file here?
Message 5 of 12
BrianAbbott
I can forward the drg. to you tomorrow, I'm working on a project just now and need to get it done for tomorrow when I have more time.
This is not my first attempt at rendering 3D. I've done a few for planning submissions in the past.
Thanks for your help.
Message 6 of 12
BrianAbbott
Hi, I’ve attached the graphics, it’s the Quadro P4000 and I’ve also attached the drawing
which has been causing me problems.
It’s a simple extension for a social care project which I’ve tried to render which has been slow to respond
or freezes, the size of the drg. is 12MB.
The camera angle I’ve been using is camera 2.
Your input and assistance would be appreciated.
Regards Brian.
Message 7 of 12
BrianAbbott
Hi pendean, attached are the graphic settings.
Thanks Brian.
Message 8 of 12
pendean
Community Legend
Community Legend
Thanks for the DWG file: I have the same video card here.
Other than what appears to be a lack of exterior lighting in your model (nice glow from the inside), rendering time from the position the DWG opened at on my slightly faster processor and double-your-ram Workstation took about +/- 3:43 minutes (my tower's fan got a workout from it).
Camera 2 Preview is also on the dark side but instant
Rendering from Camera2 has same issues as previous rendering, but did not take much longer to create here
No errors were detected in your DWG file.
Can you post a screenshot of your GRAPHICSCONFIG command pop-up?
What changed with your setup recently? Is this the only file acting up right now?
Message 9 of 12
BrianAbbott
Hi Pendean, I've attached the graphics performance as you've suggested using the command GRAPHICSCONFIG
and I've taken a screen shot of the Task Log, which may help.
The computer I'm working on replaced and older computer with AutoCAD 2012 which never presented any problems. I started working on the this computer just before lockdown and cannot recreate the quality of render models carried out before. I've tried altering the light between warm and and white light but I'm still unable to get a satisfactory render quality.
Would improving the processor and increasing the RAM make a difference as the drg. is almost now unworkable.
Thanks for your assistance.
Message 10 of 12
pendean
Community Legend
Community Legend
You appear to be running an older driver than mine in AutoCADARCH 2021.1 here. And my Tuner Log has way more entries than your "true" responses, so that may have something to do with it.
I also have LINEFADING and LINESMOOTHING variables turned off, not sure it matters but it might help you do to that as well. I don't think more RAM is your issue.
See what others jumping in here offer for ideas to try.
Message 11 of 12
BrianAbbott
Thanks Pendean, I'll start with LINEFADING and LINESMOOTHING.
Message 12 of 12
pendean
Community Legend
Community Legend
... and the driver update.
