Reference Manager
Reference Manager
Reference Manager
Re: "Reference Manager" I can't seem to control the usability relative to resolution of the program. The program opens and displays with a font size that is too small. I can not seem to control this, am using 4K resolution.
David_W_Koch
What version of AutoCAD Architecture are you using?
On what operating system are you running AutoCAD Architecture?
Supposedly, AutoCAD (Architecture) 2018 and later are set up to handle 4k monitors; earlier versions have issues.  This Autodesk Knowledge Network article gives some suggestions for earlier versions.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
If you are running 2017, the AutoCAD 2017.1.2 update is supposed to address most text scaling issues.  There are some suggested things to try for 2016 and earlier.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Thanks for taking the time to answer.  Reference Manager is a stand alone program that I don't think has had the 4k kinks worked out.  I used to use occasionally, but annoying to have to change resolution to use.
