Redifined block with attribute breaks attribute field function
How is everyone living? I have the the problem.
Situation: I have a block with some attributes. There is an attribute for column number and attribute for row number. Also, I made an attribute with field function that stores column and row attributes values. So what ever i change row number or column number the "marking" attribute updates it self.
Everything seems to work perfectly until...
Problem: I store this block in specific drawing. So if i need this block i just insert it through "Design Center". If I edit block in the original drawing and then redefine it in working drawing the "Marking" attribute losses connection to column and row attributes. And then it displays: "##"
Question: Have I done something wrong? Maybe there is a fast way to repair this attribute so it will regain the connection to those attributes (I tried "ATTS" command but it didn't resolve the problem)? Maybe you could explain me why this problem occurred so that I won't make it again? Is there a way to redefine such a block so that it won't mess up my attributes?
