Quick Properties - Attributes not displaying
alogan
Message 1 of 14
alogan
Recently upgraded from ACA 2011 to 2016, and so far the only problem I seem to have is that Quick Properties will not display Attributes. When I edit via CUI the checkboxes are in place, but a strange thing I noticed is that I get a popup with pressing OK/Apply about an empty menu (P&recision) <- that's not a typo.
Edit: Actually, I notice that the only options that display in Quick Properties are the top 3, General: Color, Layer, Linetype. So it's effecting more than just Attributes.
Any ideas?
See attached screenshot.
Aaron
Replies (13)
Message 2 of 14
alogan
SOLVED!
Installed Service Pack 1 and hotfix 1, and the Quick Properties now displays properly.
Message 3 of 14
mikeshick
I have this problem on Arch 2022 and Civil 3D 2022.  Any advice?
Mike Shick
www.medesigns.us
Message 4 of 14
pendean
Community Legend
Community Legend
Message 5 of 14
mikeshick
Link just goes to this same posting.  Not sure what you're indicating.
My programs are uptodate.
Mike Shick
www.medesigns.us
Message 6 of 14
pendean
Community Legend
Community Legend
Good to know both of your programs are up to the 2022.1.1 updates in ABOUT command for each.: you never mentioned it in your first post.
Can you post a video of you setting WPM as you desire it for attributes, then selecting the object where these stop appearing as noted in the very first post in this thread? Use PROPERTIES command to identify the object first (show it fully expanded) or share that snip of the DWG file here (as a DWG file) so we can follow along with your video.
Autodesk's Screencast is a free recorder to use https://knowledge.autodesk.com/community/screencast
Message 7 of 14
R_Tweed
I just posted the same question in the C3d forum for 2021.  Arch 2021 works fine. I'm having the issue with C3d.  See captures below.
Message 8 of 14
pendean
Community Legend
Community Legend
DWG file with the problem in it please: we all have R2022.1.1 to test and confirm if it's a prevalent or isolated issue.
Message 9 of 14
mikeshick
Actually, Civil 3d has had this issue for a number of years.  My architecture started working after closing and reopening, without further troubleshooting.  However, Civil 3d just has a permanent bug.
Mike Shick
www.medesigns.us
Message 10 of 14
R_Tweed
File is attached.  It works in our Arch'l, just not in C3d.
see ( screencast )
Message 11 of 14
pendean
Community Legend
Community Legend
>>>... It works in our Arch'l, just not in C3d. ...<<<
@R_Tweed @mikeshick C3D's forum is over here (where most users helping other users actually have that software) https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
You can report C3D issues/ideas/wishes here https://forums.autodesk.com/t5/civil-3d-ideas/idb-p/31
HTH
Message 12 of 14
mikeshick
@pendean You've always been so kind in the past.  Are you ok?
Mike Shick
www.medesigns.us
Message 13 of 14
pendean
Community Legend
Community Legend
@mikeshick Did I write something wrong? Forgive me if it appeared to be, just pointing out most users in here, unlike you both, do not have C3D to test.
Message 14 of 14
mikeshick
Maybe not.  I might have ready your last few posts wrong.  Sorry.  Glad you're well.
Mike Shick
www.medesigns.us
