question about door and properties
Dear Sir/Madam
I want to ask you something.i was watcing a video from the lybrary lynda.com and the proffesioanal appear this window,when he press the button standart sizes appear all numbers that you see.
when i make same steps with the proffesional i have not same resaults.why happen this?and how can i fix the misttake?because i want to have same resaults with the proffessional.
dbroad
It looks like you started a new drawing with no template using metric units.  The sample from the instructional video shows that they used a US Architectural template (ether STB or CTB).  It comes preloaded with sizes in imperial units.  If you want to use metric units, start with an ACA metric drawing template (not a no template option).  You can also add standard sizes by right clicking on a door once placed and then choosing edit style.  There is a dimensions tab that could let you add other standard widths and heights.  Then they would show up in the properties palette.
Architect, Registered NC, VA, SC, & GA.
