Properties and Command Line Text too Large
Hello! I am on a Mac using bootcamp, so my AutoCAD 2016 is on the Windows side. I am getting distracted by the enlarged text on my properties window and command line below. I cannot even read all the text when I scroll down for options, because it is cut off on the bottom and sides.
Does anyone know how to fix this? I attached a photo to help.
rkmcswain
Your screenshot is 2800px+ .... I wonder if it's this problem?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
R.K. McSwain     | CADpanacea | on twitter
Thanks for the response. I actually have tried all of those things from the thread you linked. I have the resolution at the Recommended/Highest level because it gets worse when I try to make the resolution lower. I can barely see the drafting space now. See attached photo.
Actually I just restarted my laptop after I adjusted the resolution and it worked! Yay! Thanks.
