Project Navigator/Browser Palette GONE! I need it back ASAP!!!
lindyrae
Message 1 of 8
lindyrae
I accidentally closed my palette for Project Navigator and cannot find out how to get it back to save my life.  We do all our work in Project Navigator in our office so I'm stuck until I can get it back.  Does anyone have a command prompt or menu option to get it back?!?  I'd really really appreciate it.
Replies (7)
Message 2 of 8
KathyMoffa
The command is AECPROJECTBROWSER
Message 3 of 8
lindyrae
That's not it.  I can access that just fine.  My problem comes into play after I've chosen the project and it supposedly loads.  I have no palette to navigate files within the project.
Message 4 of 8
Keith.Brown
try PROJECTNAVIGATOR or PROJECTNAVIGATORTOGGLE.
Message 5 of 8
lindyrae
Ok, after clicking on anything and everything I wasn't afraid to lose a cursor that had an arrow on either side <-||-> showed up and when I moved that from side to side, low and behold, it was hiding there.  It was not anchored and had hidden itself behind the main window (explains that even when I tried minimizing/not full screen size it didn't show up either.
Message 6 of 8
lindyrae
Thanks Kathy & Keith, but based on my previous reply, none of those commands did me any good unfortunately.  But I appreciate the help all the same!  Seriously thank you!
Message 7 of 8
Keith.Brown
Glad you got it working but PROJECTNAVIGATOR and PROJECTNAVIGATORTOGGLE are what brings up the palette or dismisses it.  If either of those commands do not work then you have other problems as you found out.  Another thing that can happen is the palette shrinks so small that it is just a sliver on the side and is difficult to see.   In order to fix it you would need to hover the cursor over the area near the edge until you get the drag icon and then you can drag the palette to a more managable size.
Message 8 of 8
lindyrae
Keith-  I had typed those commands about 5 times a piece before even posting to the forum.  And my problem was exactly as you described in your last post.  It had become so tiny it simply looked like the edge of the program window.  The drag cursor popped up and allowed me to find it hiding there.
