plot pdf from sheet set dont work
Message 1 of 10
hi
when i plot pdf from sheet set ( plublish to pdf)   the job dont finish cad 2015
steel saying : publish plot in progress  for long time more than an hour ?
thank you
Replies (9)
Message 2 of 10
leothebuilder
Do you have page setups defined?
Message 3 of 10
hi
yes page setup is difined , see attachement
Message 4 of 10
leothebuilder
Ok....Have you tried publishing one sheet only from the sheet set?
What happens if you use the Publish command (without using sheet set)
Message 5 of 10
I dont use This commande , i Will try it and see what happen
Message 6 of 10
pendean
Community Legend
Community Legend
Do you have background publishing turned on? Turn it off, it's in OPTIONS command.
Message 7 of 10
i'ts working wont to turn off ! mybe after the plot i will turn it off
Message 8 of 10
publish does not work too , it did the same thing
Message 9 of 10
leothebuilder
Ok.....
I think your page setup is at fault here, it is not properly defined.
I would redefine page setup to use a plotter or printer.
Do you have or use a printer or plotter?
Define the page setup for that printer/plotter and set this page setup current.
Apply this to all sheets in the sheet set.
Then right click the sheet set and select Publish to PDF.
Message 10 of 10
plotting works for my colleagues in the same configuration , but not mine , i will try this it will take time , i will tell you tomorrow that happen , thank you verry mush
