Hope the attached will be helpful. Project level cut planes and constructs might be different for walls, curtain walls etc.
- Uncheck the window style or object display option to "Use Cut Plane....";
- Set the wall cut plane to intersect the lowest window (using 'cm' as unit here);
- Check the wall style or object display option to "Hide lines below...";
- Result
