MText Masking Transparency?
BBP-Arch
BBP-Arch
ACA2020
So in Mtext, there is a small 'Mask' icon in the ribbon. It allows the creation of a mask for the text to go over objects. Very cool.
Question: Is there a way to make that mask SEMI-transparent? It would be great to lightly see walls, objects or whatever underneath that text. I had used this mask recently and it was over a wall which then looked like I'd put the text strategically in an opening in the wall beneath. I thought if the wall could've have been seen at 50% or less through the text it would be helpful.
Scott
pendean
Community Legend
Community Legend
No, you either need mask or not, there is no option to "see through" a mask 😉
