Modifying Casework through Walls or adding Vertexes to customize Casework on an Angle
crleslie
crleslie
I've been stumped on this for almost an hour now..  Been trying to use the cleanup command but it's always getting me to edit the diagonal wall rather than the casework.  I would think it would be simple enough to add a vertex to the casework wall but there's no option to do so.  I must be missing something it can't be this hard to prevent casework from going through walls like this.
Is there a way to prevent casework from appearing on the other side of the wall?  I tried using polylines and interference subtraction, etc. nothing seems to work that I think would.
David_W_Koch
What object type are you using to model the casework?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pendean
Community Legend
Community Legend
Share your actual DWG file here please @crleslie
R_Tweed
The interference condition would need to be a mass-element large enough to enclose the end.
If you are using a wall style, this can be done with and end cap style.
It takes a little time to setup the first time for each component but once you have it you can get fairly detailed.
