Mid between two points object snap is not appearing in the short cut menu
One of the CAD engineer in my office is facing with a new problem. Until two days back she was able to use the "mid between two points" object snap. But recently it dissappeared from the shift+right click short cut menu. Do any one of you know the method to bring it back to the shortcut menu?
Sunilkumar
Formshore
CALICUT
pendean
Community Legend
Community Legend
Did your use load a new CUI screen menu, or load/change to a new WORKSPACE in AutoCAD?
I already copied the cui file from another computer and solved the problem. I was looking for any specific settings which controls this feature. Anyway thank you for your valuable advise.
Sunilkumar
Formshore
Calicut
pendean
Community Legend
Community Legend
The "specific settings" are they were missing from the correct category in the CUI file, either deleted by the user or not there in the first place: your solution is the quick fix, the other is to manually put it all back. Glad it worked.
