Map IfcObjectAttributes [IfcBuildingElementProxy]
Hello together,
I use AutoCAD Architecture 2022. My goal is, to write not graphic information into an IFC file. This information is attached to block references with 3D objects in her definitions.
I copied for that IfcBuildingElementProxy from file IFC_Object_Attribute_Pset_definition.dwg into my drawing.
than select in tab Applies To box Block Reference.
added an own Manual Property definition, called Power
add the property set to the block reference
enter a Power value 235 and put in the exist attribute for testing purposes the value TestA
The command IFCExport writes value TestA in the IFC File.
but from my own attribute Power attribut nothing can be seen in the IFC file. What am I doing wrong?
IfcObjectAttributes [IfcBuildingElementProxyType] does not work too.
All graphics of the objects are well transferred.
Thanks in advance!
