Layout Tabs Duplicate
heather_o
heather_o
When I need to publish several of the layout sheets at the bottom of the screen, I will hold the shift button while selecting the tabs I need.  Sometimes, not all the time, it will duplicate the tabs.  I could have sworn there was a way to turn this off and I did.  This hasn't happened to me in years.  Well, I had to get a new machine and now the duplication is back.  Is there a way to turn this off?
David_W_Koch
I am unable to replicate that behavior in ACA 2024.
CTRL+drag will duplicate the currently selected layout(s).  Any chance you are catching the CTRL key when you press the Shift key?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pendean
Community Legend
Community Legend
... or replace your keyboard and try it again (wired old-school keyboard for testing purposes is ideal).
heather_o
There are times when I do use CTRL vs SHIFT.  And I must be dragging without knowing.  I wish there was a way to turn this feature off.
heather_o
I went to a coworker and asked her to hold the CTRL button down and drag to create another layout tab.  She couldn't do it.  There must be a setting that turned this feature off, right?
pendean
Community Legend
Community Legend
@heather_o wrote:
....There must be a setting that turned this feature off, right?
Nothing turns that off inside AutoCAD as far as I know: but you can't copy to the very end of the row easily either, much simpler if you aim for between other layouts.
Can they right-click and select "copy"?
