AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Layout dimensions smaller despite all units matching
1 REPLY 1
lkrstic2023_10289
124 Views, 1 Reply
I have premade A3 frames to copy and paste from another CAD document to a prefered drawing. In a drawing I'm currently working on I set up layout page in mm for A3 and 1:1, in model space ratio is 1:1 and drawing unit is mm. In my premade document ratio is also 1:1 and it's also drawn in mm. Yet when i try to copyclip from a premade doc to layout space, the frame is a lot bigger than the paper. Any solutions?
Tags (1)
1 REPLY 1
pendean
in reply to: lkrstic2023_10289
"A lot bigger" like perhaps 25.4 times bigger by chance? A quick measurement will confirm you are in an INCHES units DWG file most like if so.
DWGUNITS command, not UNITS command, can confirm the above too in your destination file.
HTH
Technology Administrators
