key commands not working anymore
I am hoping this is a quick fix someone might know about.
My key commands no longer work the way they used to.
EXAMPLE - "ctrl + O" should open up the File Open pop-up. Instead it only creates a command in the Command text input line.
Any ideas how i restore key commands so they work properly?
thanks
David_W_Koch
Is the FILEDIA system variable set to 1?  If not, do so.  Does that make things work?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
