Jumping Crosshair
Jumping Crosshair
kenny_houston
Jumping Crosshair
kenny_houston
One user out 60 is experiencing jumping crosshairs.   We have determined that if you turn off the display of coordinates on the bottom menu the condition stops.   Turing on coordinates causes the crosshairs to jump or even bounce back and forth sometime.    Is there a way to fix this?
Thanks!
dbroad
Just a guess but are you talking about the snapgridlegacy behavior being set to 1?
Architect, Registered NC, VA, SC, & GA.
bryce.thelin
It sounds like you are maybe dealing with the issue we have documented here:
http://knowledge.autodesk.com/article/Status-bar-toggles-between-one-and-two-rows-in-AutoCAD
Bryce Thelin
AutoCAD Product Support
kenny_houston
Turning off the coordinates seem to work, but this is AutoCAD 2016.
