AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Is there any method to add a 3D Solid to Custom Stringer in Stair Style?
1 REPLY 1
jtm2020hyo
464 Views, 1 Reply
I did not found a method to add a 3D Solid using the Body Modifier command but does not appear in the Stair Component list:
PD: attached file
1 REPLY 1
R_Tweed
in reply to: jtm2020hyo
No.  I find it easier to use mass elements or sweep a profile and use that in place of the the stringers. I'll use the stringer as housed or full slab to enclose the underside as a quick run, but when I want detail, I make them separately.
Forma Design Contest
