Is Merge Common Materials Reliable?
jimkedmondson
Message 1 of 10
jimkedmondson
Is the merge common materials considered reliable?  I'm working with ACA 2015.  I was generating 2D elevations from a composite xref'ed model and getting weird results, such as disappearing walls.  Interestingly, if I refreshed the 2D section / elevation item, the linework results would change - walls would appear and disappear.  This was without adding or changing any content.
Anyways, I came across an old post saying materials merging is not reliable.  (I remember this was the case with ACA 2007).  So, I turned off this feature and my elevations now come in correctly (no transparent walls) and in addition, the component design rule I had defined now works (footings to hidden line).
Is it best to avoid materials merge?
Jim
Replies (9)
Message 2 of 10
alexKoshman
I think I know what is it.
IT'S A BUG of the poor old "2D Section\Elevation" object... For VERY, VERY complex model...
If it is so, you can try to:
 - SHORTEN your Section Line and then copy it (and then construct your "2D Section\Elevation" object from two of them, for example)
or
 - SHORTEN the depth of the Section\Elevation.
If your bugs then disappears - it was the bug!..
Message 3 of 10
E-Lavoie
On 2015 its not that bad, you need to have your floor at exactly the same location, i mean wall over wall, not even 1/32" of a difference, to not have problem. On 2016 its not reliable at all, they are supposed to be working on a fix.
Message 4 of 10
jimkedmondson
Thanks.  I had it working before and was pretty stoked.  Then, it stopped working.  Maybe I "nudged" the xrefs.  I'll go back and check.
Jim
Message 5 of 10
alexKoshman
It's not your fault!
It's of Autodesk's programmers!..
Message 6 of 10
jimkedmondson
Why oh why is this still occurring in 2015?  I had this issue in 2007.  Is this rocket science, Autocad?  Are you listening?  🙂
Jim
Message 7 of 10
alexKoshman
Because it's NUCLEAR ROCKET science!!
Message 8 of 10
jimkedmondson
Message 9 of 10
alexKoshman
Ha-ha!
I think they read this book NOW... In place of enhancing their own software!.. ; ))
Message 10 of 10
alexKoshman
My dear jkedmondson!
You aren't right!
It wasn't the Solution.
It was only a version of how (and why) it may be!.. ; ))
