Hello, I tried to install ACA 2k8 through GPO, but got the same error.
On this help link http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8164400&linkID=9240617 a saw the help, but dont know what exactly to do.
I found the folder with system profile: "C:\WINDOWS\system32\config\systemprofile" and the registry value "HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders".
System profile has the following structure:
C:\Windows\System32\config\systemprofile\ntuser.dat
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}
C:\Windows\System32\config\systemprofile\AppData\Local
C:\Windows\System32\config\systemprofile\AppData\LocalLow
C:\Windows\System32\config\systemprofile\AppData\Local\d3d9caps.dat
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Portable Devices
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Portable Devices\wpdlog00.sqm
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\SchCache
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\SchCache\*domain*.sch
C:\Windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}\mxdwdui.dll
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}\mxdwdui.gpd
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}\mxdwdui.ini
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}\prnms001.cat
C:\Windows\System32\config\systemprofile\{17fc81a2-b1***}\prnms001.Inf
and the registry value 'Shell Folders' is empty:
Windows Registry Editor Version 5.00
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
Can you help me please?
Thanks in advance,
Lukas
