How to show doors on the RCP?
On a RCP copied from another previous project, to use in a similar project, the doors (which are on layer A-Door on the background of the Floor Plan) do not show on the recipient background of the RCP.  The background source Floor Plan is X-refed into the new recipient RCP background, and things show there except for the doors.
How can the doors show?   (I prefer the doors to show on the RCP since that helps to locate the switches and also the exit signs, etc.)
Thanks in advance.
dbroad
Switch to the Reflected Display Configuration.  Pick a door, right click and edit the style. Choose the "Edit Display Properties" button without checking style override.  Turn on the "Below cut plane" representations on the layer/color/linetype tab and on the other tab uncheck override opening percentage.
Architect, Registered NC, VA, SC, & GA.
Not yet.  Very complicated set of steps and not for the fain hearted.
I am using version 2020.
Where is the "Reflected Display Configuration"?  (The doors are not shown on the RCP)
dbroad
Then just key in the door command. Choose the styles option.
R_Tweed
maybe screencast will help?  (here)
