How to set Layer Key Styles to Current Layer
Is there a way to set the Layer Keys to the current layer so when I add a wall, window, door, etc. it gets created on whatever the current layer is?
Figured it out. Go to Drawing Utilities, go to Drawing Setup, go to Layering, then under "Layer Key Style" select <Current Layer>. Make sure you check "Save As Default" so the key style won't change.
If you use CAD almost entirely in-house and work at a small-sized firm, you really don't need to use a national standard. So using your current layer can help to keep things simple and clean.
