Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to place an altitude dimension on a 2D drawing?
kostimea
kostimea
How can I place an altitude dimension on a 2d drawing?
Victoria.Studley
Hi @kostimea,
Could you say a little more about what you're trying to achieve here?
  • When you say "altitude", are you referring to elevation?
  • In plan view or in section/elevation?
There are elevation labels available in AutoCAD Architecture, which you can find more information about here:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
kostimea
Thank you for your reply, that is what I am looking for. I would like to use it in a plan view. I have drawn an elevation with2d elements in a view file (not generated from a 3d model) and I need to place the dimensions on it.
I have found the elevation label tool, have set my z axis, placed a label. The elevation height shown in the label menu is correct ( 2,82m) but the label placed on the drawing shows a different number(+110,0000).
Victoria.Studley
Hi @kostimea,
I'm glad this has pointed you in the right direction.
Could you post your file with the Elevation Label that doesn't display the correct value?
I'll be happy to take a look to try to determine what is happening.
Victoria Studley
