How to create door or window tag?
Ali.Katebi
Message 1 of 12
Ali.Katebi
Hello
I write window and door size in side of them like this: 36"x24"
How can I create a door and window tag in ACA as attached picture?
And please tell learn me for download and install more tags.
thanks so much
Replies (11)
Message 2 of 12
dbroad
Have you tried to search for the answer yourself before making your post?  There are certainly hundreds of posts about this.  On the annotate tab, on the scheduling tab flyout, push "create tag" (scheduletag). Then hit F1 to get the system help.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 12
Ali.Katebi
Yes I tried a lot. I asked two questions and both of them is important for me:
1- How to create (How can I learn to create tag). You told me where is that icon but I should to learn. So if it is possible please send me a link for learn to create tags.
2- Second my question is about how can to add more tags. Where can I download more tags.
Message 4 of 12
David_W_Koch
Searching the on-line Help for create schedule tag gave me this article,
http://help.autodesk.com/view/ARCHDESK/2020/ENU/?guid=GUID-185BF421-746C-4E2F-945A-B9C03028A15A
which covers the use of the tool to which @dbroad pointed you.
If you prefer a more wordy explanation, then you may find these blog articles of use:
http://architects-desktop.blogspot.com/2005/03/adt-2006-tags-illustrated.html
http://architects-desktop.blogspot.com/2008/11/creating-annotative-tags-in-autocad.html
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 5 of 12
David_W_Koch
As to your second question, I am not certain I know of a place from which you can download tags.  They are so easy to create, are often tied to a given firm's (customized) Property Sets and the desired graphics are often so firm-specific that creating a repository may be more work than it is worth.
You could try searching the forums here, for example content that was posted in response to a particular question.
David Koch
Blog | LinkedIn
Message 6 of 12
Ali.Katebi
That's good.I will try and share my problems with you if needed.
Thanks you so much.
Message 7 of 12
dbroad
I see you've gotten your answers.  Exploding tags should give you a good idea of how they work.  I think the link david meant to share is
As far as a step by step, you may watch this screencast (no sound).
Message 8 of 12
dbroad
I see you've gotten your answer.  Hitting F1 in the definetag command should get you a good start.  The wordy link that David posted should probably have been, since the one he posted seems broken
Here is a screencast step by step.
Message 9 of 12
dbroad
I see that you've solved your problem.  Exploding tags and hitting F1 in the definetag command are what work for me.  David's wordy links seem broken. Try this:
Here is a step by step screencast
Message 10 of 12
Ali.Katebi
WOW... really perfect. I searched a lot but I couldn't find like this video, I needed exact like this . Really thank you for share this video.
Message 11 of 12
David_W_Koch
Odd, both those links do not work.  Apparently, cut and paste is not what it used to be.
Perhaps these will work better:
https://architects-desktop.blogspot.com/2005/03/adt-2006-tags-illustrated.htm
https://architects-desktop.blogspot.com/2008/11/creating-annotative-tags-in-autocad.html
It seems that links in the older articles are to http, not https, and the insecure version of the links no longer works.  I will have to try to remember that in the future.
David Koch
Blog | LinkedIn
Message 12 of 12
Ali.Katebi
On the same day, I was able to retrieve both links.
Anyway, I sincerely appreciate your sense of responsibility.
